Bubba,Can you take some side view pictures showing how all the pulley,are aligned?
I will get some pictures later this week. We are doing the big Mothers Day thing tomorrow so no garage time.
Chad,i guess ur in Fla...not many machinests? Anyway, after a good try, as last resort, a reduction in width might work?
Long as the belt still fits (actually that's abt the time I get the shims out - to answ an early different Q).
I have not tried to install the 2 groove dampener because of the condition that it was in. I went ahead and bought a dampener from Damper Doctor before checking with Vintage Inlines. It ended up costing me about $40.00 more. I wish I would have thought of them first. Shame on me.Thank you for posting those pictures this sure helps me alot to see the actual parts your trying to use. I now can better visualize why the pulley's you were trying to use weren't lineing up correctly! The Pulley aliamment on Fords is usually always perfect so this is not normally a problem that it can be on some other brands that I have worked on where so crude that pulley's won't line up very well without lots of shimming. Yes I think you are now going about it in the right way using that double grove Dampner is the best way to get were you need to go. The early single pulley dampener that you have on your 170 with the single add on pulley matches correctly but that can be the problem when trying to mix and match these pulley's that are from the wrong Dampner pulley groups. Yes that single Dampner has a flatter face so it's going to need to use pulley's from its own group of add on pulley's that will fit on it correctly. So if you wanted to use an add on a double grove pulley with your single grove dampener it would need to have the exact same back spacing as your current single add on pulley dose in order for it to fit right.
There is also going to be a single grove add on pulley made that has the right offset that will fit on that double grove Dampner too. But that add on pulley's back spacing offset would need to be the exact same as your double grove add on pulley is in order for it to bolt on and line up correctly with the other pulley's. That FM-6318 number makes that double pulley an aftermarket one that were often used by companies like ARA doing the add on aftermarket Air Conditioner systems. https://www.arasourcing.com/ara-systems-inc.html
Did you try that double grove pulley on .your engine to see if it lines up better with the water pump pulley? Best of luck Edited
Too late, I should have looked. It would have saved me about $40.00. I had already ordered one from Damper Doctor when I saw your post. Live and learn.Matt has single, double and trip (like mine) dampners...
www.vintageinlines.com-Short Block 2/3
I have the Ford factory manuals for a 1965 Mustang and a 1964 Falcon. I just wanted to make sure I wasn't missing anything.Scan the whole article, I think its all here, just a lill spread out: no hammer, no press on 'outside' only (separates inner metal from outer - ripping the middle rubber, etc). I thought I might have seen everything. No Chiton's or Haynes available? No buds for 'boots on the ground' 'supervision"? List it all back. We can ck 4 accuracy~
I bought them both from an online auction for a Vintage Ford repair shop that closed in Minnesota a few years back. It was more in shipping than the bid price for all of the shop manuals I bought. The falcon one was $1.00.I sometimes wish I could afford that level of manni even w/the electronics today,
did the last site have U fishin off the back ofa row boat for
