Electric radiator fans are common but would like to hear from anyone using or considering adding the electric water pump also. I read that the electric water pump can adjust their speed to match demand, reducing unnecessary power consumption and maintaining a target temperature. Apparently many major auto companies are using electric water pumps so they must be generally reliable. If the electric pump can move more water than the stock pump when required that could be a benefit for those living in hotter climates.
Electric fans are easily available at picnpul and have read that a Taurus 2 speed fan is popular and have also seen those using 2 smaller electric fans that can activate one fan or both as needed.
Not sure of any impact on the belt number and arrangement without the water pump pulley present. My Bronco has alternator and ps while others may have an ac compressor as well.
My recent considering using an electric fuel pump as a future modification prompted this as it seems new fuel pump quality is apparently not good.
