Howdy Paul:
I know it makes know sense, but FoMoCo used the same casting codes on all small sixes, so the casting code is only good to tell you about when the block was engineered. it was cast sometime after that. If your engine has a three bolt water pump then it is most likely a 200. Also take note of Rocklords tip.
