Yeee Haaa
After almost a year i started the Falcon this afternoon I put 103 octane avgas in it set the timing at 7 deg btdc set the float level, wastegate set to 7 psi and off up the road......
turbo spooling up nicely lots of noise
I went gently on her as it has only 3 feet of 4 inch exhaust and its hard to hear the tune(exhaust comes next week)
It made around 5 psi spiked to 8 and blew the cork carb hat gasket i made so will look into something better for that
I was quite pleased with how it ran considering how little had been done to the tune Number 74 Jets and the solid float is all
There was no detonation so i guess ill advance it a little and see what happens .
Unfortunately I have urgent work to do for the next couple of days so wont get to try anything for a while
Ill let you know when i do
