I6BLUEBIRD
Don't let me buy a V-8.
My wife just got over the fact that I bought the car. I think an engine swap might send her over the edge.
I'm sure that you have heard this a thousand times..." need a little more power."
I saw a post today (realistic limitations / rommaster2) that described adequate accelleration at speeds below 45mph. This is exactly what I have not been able to achieve.
I am not looking for tire smokin', neck snappin' low end power. I would like to pull into traffic without waiting for a 1/8th mile gap, or to enter an expressway at more than 50 mph at the bottom of a downhill on ramp.
Could my problem be as simple as a carburetor? I'm hoping that you can help me boost my low end power...or tell me that I'm expecting too much. Here are the details that I can provide.
1965 Falcon
200 cid (1968) Pertronix added... runs very smooth
C4 trans
3.20 rear gear
20 in. Hg Man. Vac @ idle
120 lb psi cyl. comp. at every cyl.
initial timing set at ~20 deg. btdc (vac advance works well)
plug gap @ .042
The only problems that I have with the way the engine runs is a Hesitation at initial accelleration (sometimes). I know replacing or rebuilding the carb will fix that problem. But, could my lack of low end be that simple?
Thank you all for the help that these threads have already provided. You have gotten me this far.
1965 Falcon
C4 trans
3.20 rear gear
plug gap @ .042
