Hi, i looking @ buying a kit for 250 Xflow to accept I6 T5's (EA-EL) and wondering on a few bits of into on the T5 if possible.
1st.. length of gearbox (not including the bellhousing as it uses the XF T5 bellhousing)
2nd.. length between gearbox and shifter (to see where the shifter would come up in my car) (1977 TE Cortina)
3rd.. a good photo of a T5.
4th.. if possible width of T5 also (evne tho theyre should be heaps of tunnel room as the BW35's are pretty wide n bulky)
the kit im buying comes with the following..
<Quote>
3500lbs custom modified and balanced XR8 Clutch (standard is 1800lbs)
Balanced Crossflow flywheel re-drilled to suit heavy duty clutch
Factory XF falcon bellhousing to suit Crossflow six
New clutch cable, XF falcon update type with threaded adjuster instead of E clip
Clutch fork and throwout bearing. (T5 has the clutch fork exit on the passenger side away from exhaust)
Modified crossmember for TE / TF Cortina.
</Quote>
<Quote>
</Quote>
