Ignition Help!
I am trying to replace the ignition housing on a 66 Mustang. It separated behind the firewall. I have removed the ignition assembly and am trying to figure out how this unit goes back together. Does anyone have a pictorial or breakout of the ignition assembly? The replacement I bout has contacts, where the original has the wiring coming out of the housing. If anyone has wiring identification (4 wires) that would help also. Thank you.
http://pg.photos.yahoo.com/ph/southernc ... .dir=/d9f8
I'm confused with your problem description. Are you talking about the key switch in the dash, or some part of the wiring harness (i.e. a connection) near the firewall?
The link you put in did not work.
Scott
