350kmileford
I've been running the Performance Distributors DSII ignition kit from ClassicInlines for about 6 months now. The ignition system has been working awesome but there's a potential issue I've always worried about but never looked into. The ignition wire resistor that runs from the ignition switch is EXTREMELY hot when I am driving the car. It has melted electrical tape and 2 zip ties. It will burn skin instantly. For those unfamiliar :
Any ideas, reasons, suggestions?
http://classicinlines.com/proddetail.as ... 0-DSII-KitFor street applications, the enclosed gold resistor must be used which will limit maximum rpms to 6500. The resistor is used as a precautionary measure to protect the coil and module from premature failure on long periods of running time. Even with the resistor in the system, the firepower from this kit is still much hotter than stock from idle to 6500. For all out racing applications, the gold resistor is not utilized, allowing the system to produce an intense spark up to 10,000 rpms. The kit includes all wiring with easy to follow instructions.
