is the 170/200 and 250 the same timing set ?
hello, I build a 250ci 73 for my mustang and I search a timing set.
And I would know if the 170/200 and 250 are the same timing set.
Thanks a lot
Dynagear lists the 250 as 73016
and the 200 as 73018,
So I am assuming since differnet part numbers, they will be different sets.
yes i beleive the timing set for a 250 is bigger than a 200 seeing as mike is asking for the lengths between the gears so he can get started on making the double roller chain
