8) it is actually, though improperly, called dieseling. what is happening is a fuel source interacts with a combustion source, and keeps the engine running. usually the idle speed is a bit high, along with the throttle plate being too far open, and that is coupled with a glowing carbon ember in the combustion chamber to create the problem. start by lowering the idle speed, by closing the throttle plate. if you need more idle speed, then bump the timing a couple of degrees. i would also run about 32oz of water through the system, SLOWLY to prevent hydrostatic lock, then run the car on the freeway for a bit. you can also use seafoam green run through the carb or the fuel tank.
