Today we were screwin around with the 170 again with a re rebuilt carburetor from garenteed carbs of florida. They upped the jet size for us and it helped a little bit, but what i would like to do right now is try to provide a description of what is going on with the car. while screwing with the car today we adjusted the timing up to about 18 btdc and it started to gain rpms and smoothed out adjusted the carb idle air screw and it jumped from 500rpm to 700 with those two tweaks. I think that the best way to describe what is going on with the car is that it will idle really nicely for a few seconds then it will get rough and miss repeatedly on in no true pattern sometimes this will only last a second sometimes just as long or longer than it will idle nicely. We have replaced the entire ignitions system with no change and the carb has been rebuilt and rejetted twice professionally. we have adjusted the valves repeatedly the manifold vaccum is right at 18.5 in and the engine is in perfect mechanical condition.
I am out of ideas.
The only question i have is how much being bored out .040" and a fel-pro headgasket will affect the cr and if that could be the cause at all. i know the head needs to be milled, but is it possible that it could cause this?
I am out of ideas.
