leaky freeze plug
rustywagon
Freeze plug at the back of the engine (facing fire wall) is leaking, I do not wan't to pull engine out. Is there's safe coolant leak sealer?
"... I do not wan't to pull engine ..."
do U wanna replace the plug or pour some bad juju in the system?
Either has costs'n benies...
How often do U hafta add how much coolant?
If U can C it, U can replace it...
(jeesh? What plug is it?)
:hmmm: You could also do what a friend of mine and I too have done.Figure out where to line things up,and use a hole saw to cut a hole in the firewall and access it that way.Then just make a simple plate to secure over the hole with a piece of old inner tube glued to it for a seal.Really easy.
Good luck.Have fun.Be safe.
Leo
Hi, X2 on the rubber plug. You may gain some room to work by removing the motor mounts and lowering the engine. If you do that be careful the fan doesn't hit the radiator. Good luck
lotta dash bd ta go thru.
Mirror in 1 hand or proped up, pull radiator, loosen motor mounts, jack
