Need some help here...
Have a 83 Futura with a 200 that runs funny. Blows fuel mixture back thru carb when running and will not rev over idle and finally stalls. Replaced timing chain- no difference. Removed exhaust pipe- no difference. Removed 1 plug- engine ran longer, but rougher. Removed different plugs- same thing. Removing 2 - 3 plugs at a time resulted in an extremely rough idle but was able to rev engine considerably.
Rocker arms look fine so I,n guessing either a flat cam or collapsed lifters.
Does anyone have any other ideas? I,m about ready to order a new cam and lifter set or go with option 2 which is to swap in a running 250 &C4 from a freebie 80 granada.
P.S. Compression is 110-120 psi on all cylinders so I,d like to keep this engine.
