NC-Fordguy
Hopefully you all can help isolate the problem. I am at my wits in and I'm thinking a V-8 swap is in order as this is where my background is.
I have a 66 bronco with a 170. The truck has 89k original miles. The past six years it only had 30 miles put on it. I got a good deal I thought and bought it.
Problem now is the truck dies under load when warmed up unless I pull the choke or put the truck into low range.
I have rebuilt the carb(autolite model)
Complete tune up(plugs, wires, points, condensor rotor and distrubuter cap)
Repaired the vacume leak at the distrubuter(stripped brass nut on the vacume line)
Eliminated all vacume leaks
Tried various timing abjustment anywhere from 0-12 degrees BTC
When warm vacume reads at idle 18 inches of vacume with only a slight flicker
With vacume guage in line between the carb and distributer the vacume will get up to about 5 inches under acceleration and the truck dies.
Any ideas where the problem is???
