i recently picked up a 68 mustang with the 200 i6. the motor was really long gone so i picked up one out of a wrecked falcon. the carb on the 68 had the spark control valve spot closed off, the engine that i just picked up and came with a carb that had the spark control valve (theyre both autolite 1100s.) i look at both of the distributors and they are exactly the same. so is the difference between the two distributors noticable or not? im really confused here.
also, trying to get it to run just right. ive got the idle and mixture set up perfect. I let it warm up, and when i try to drive it, giving it steady gas it surges, and under load sometimes it dies, and after i drive it for a bit it doesnt really want to idle, anyone have any ideas? thank you for all the help you have given me so far!
-tony
-tony
