It's reported that weakening the springs on the stick distributor will increase the total advance which can lead to pinging.
A total advance stop needs to be fabricated if the spring tension is lessened.
The automatic dist. has less total advance (but more initial advance) than the stick shift.
If you are running a stick shift distributor in an automatic car set the initial timing to the stick shift setting.
I don't see any automatic LOM distributors or automatic vacuum advance units listed at my favorite parts store.
