Getting the six carbs synched is proving to be a challenge.
Change one, two others move. Adjust the idle, three carbs respond. Adjust mixture, another carb goes south. I'll get there; it's gonna take time.
There is some oil seepage on the lifter side of the block. Apparently my block mods didn't extend quite far enough to catch the front and rear oil return passages. I'll have to examine that more carefully on x-flow #2. It's only slight seeping, but it'll leave a drop or two in the morning. :x
So far, no blatant overheating, but the temps do tend to get hot. I blame that on the lack of an adequate fan. We'll see what it does under load.
It is god-awful loud.
The cam comes on at 1600-1800 rpm and the noise gets pretty wicked. Between the six carbs and the exhaust, you can't hear if anything bad might be happening. Not sure what it will pull under load, but it will easily rev to 6500 in neutral. 8)
