log exhaust manifold vs. tubular header
351 celi
So I have decided to go ahead and turbocharge the 250. Though I have signs of blow-by, I am going to let the motor eat, mostly because I already have bought most of the turbo set-up, and I can't justify rebuilding the 250 if I am not sure I will be satisfied with the end result, and I have a 351W needing the same amount of work plus some goodies sitting. I really wanted to try to utilize my header with a J-pipe, nothing fancy, only the Scott Drake 6-1 header, but I really see no easy approach to using it. I know I could do it if I took drastic measures, like ditching PS, and column shifter, routing turbo and header pipe on the driver side in place of PS pump, but is it worth all that when I can simply use the oem cast unit with a simple 180 degree J pipe? Really, how much would I gain by using the header, or does the pipe length likely negate the efficiency of the header vs log? I also am trying to come up with a simple carb hat solution, I am very limited in hood clearance, no commercial offerings will work.
If you truly have noticeable blowby N/A, you better secure your dipstick, breather and PCV valve when you boost it, everthing will be well oiled with a good oil fogging.
8) what he said.
No real gain using headers as exhaust manifold feeding turbo. OEM manifold will work fine.
Might try mounting turbo on driver side with exhaust going down and under engine then up to the turbo. Pressure outlet across valve cover to carb box / hat.
8) build a sealed box around the carb like what was used on mid sixties shelbys using the paxton supercharger. that assumes you are going to run a blow through system.
I will heed your warning about the blow by issue, thanks guys. I made my turbo flange for my J-pipe saturday, now I need to make a new heavy flange for the oem header. I post pics when I have something worth seeing...
I cant imagine running a pressurized box. Everyone I know who has run those has had problems getting them to seal properly.
A carb box is a bad idea, and is usually about as high as a carb hat anyhow. There are some fairly short hats out there, and there is a possibility you can mill one down. Might just have to have a clearance hole in the hood.
Steel tubing in the thicknesses used for N/A headers will crack and break quickly when exposed to the heat, weight and vibration of a turbo. Don't do it.
