All Small Six Lokar throttle cable connected to Weber DGV
I modded my stock setup as I couldnt get a cable system to work easily. Here's my saga if you wanna do similar:
... you didn't mention the application - ?
The cable itself is only one part of conversion, for small block six with existing mechanical linkage and pedal setup, the later Maverick /Stang etc hung pedal and OEM cable bracket setup is likely simplest cable conversion.
the '63 uses the stock mechanical linkage slightly formed (bent) to work on the Holley/Weber 32/36 version of the Weber DGV/DGA 32/36etc.
the 61's small block six cable setup uses a Maverick ' hanging' gas pedal with a factory 'over the VC' bracket used on all the later small sixes.
74 Mav' SC six OEM cable:
