HELLO 62FAIRLANE170
....YOU SHOULD HAVE NO PROBLEMS. THE 1100 IS A LITTLE BIGGER FOR A 170.
....YOU JUST NEED TO CHECK THE FLOAT LEVEL. MAKE SURE THE JET HAS NOT BEEN DRILLED OUT, ALITTLE WD/40 ON THE POWER/BOOTER ROD,AND FLOAT PIN, THROTTLE ACTION AND BUTTERFLY AREA. LOOK FOR RUST OR ANYTHING THAT SHOULD NOT BE INSIDE.
....YOU MIGHT PUT SOME GAS INTO THE BOWL AND SEE IF ALL GAS PASSAGES ARE WORKING. (IF NOT REBUILD IT NOW.)
.... THIS CARB. IS BIGGER THAN MOST THAT CAME OUT IN 1962. YOU WILL MOST LIKELY FEEL A SMALL LOSS AT THE LOW END BUT AFTER IT IS RUNNING YOU SHOULD FEEL MORE POWER.
GOOD LUCK
LIVE IN GRACE
LEROY POLL
