Bad luck with 250 oil pumps! Changed the oil last night, this morning ran fine, stopped at the store, oil light came on. Removed the oil pressure switch, not a drop came out when restarted the engine. Lifters clackin' and got it towed home.
This is the second pump on a new engine. While tuning up the motor, the oil light would come on from time to time, so I replaced the first oil pump. Worked fine after that. Replaced with a new stock pump from A&A auto parts.
With the second oil pump, it became a quart low once and the oil light came on and stayed on even after I topped it off. Removed the oil pressure switch, spun the motor, oil squirted out, replaced the oil switch, no problems till now. I've probably put over a thousand miles on since. Little over two thousand miles since I got it running.
I'm going to tear it apart this afternoon to find out what's wrong. Anybody else have bad run with oil pumps?
