Hello all
I am having some difficulty deciding which turbo would fit my needs/wants which I will list:
- 300 six
- propane fuel
- aftercooled
- 14 p.s.i. maximum
- 6400 lbs. vehicle weight
- 4 & 2 trans. with overdrive, shift points 500 r.p.m. apart
- 1900-2200 r.p.m. @ cruise speed
- engine operating speed 800 r.p.m. to 3200 r.p.m. (usually less)
- 4000 r.p.m. (or less) MAX.
- shift points usually 2500 r.p.m. or less
- low speed torque most important
- boost to start as low as practical
- max. boost available by 2400 r.p.m.
- general transportaion and towing application
- altitude 3500 ft.
- climate temperature -40 to +100 degrees F
- turbo with integral wastegate
I have used the Ray Hall calculator and have come up with the T3 50, T3 60 or T3 Super 60. Also working through the books "Maximum Boost" and "Turbochargers". I would like to discuss this application with someone who has experience with this low speed, high torque application. Most everyone I have talked to locally has experience with higher r.p.m., high horsepower applications. The TO4B that Ak Miller used
seems to be too large when applied to my specs when using the Ray Hall calculator. As such, I would very much like to hear your experiences and advice.
Thank you in advance for any assistance
MetalZ
- 300 six
- propane fuel
- aftercooled
- 14 p.s.i. maximum
- altitude 3500 ft.
MetalZ
