Came across this folder in the Yahoo MegaSquirt group. Not sure if you can see it without being a yahoo member, but heres the link anyway:
http://photos.groups.yahoo.com/grou...er=&.view=t&.done=http://briefcase.yahoo.com/
I'm not exactly sure what the deal is there, but it seems as though they aren't using a fuel pump, like the Liquiphase in-tank setup, instead utilising a pressure regulator. I dont recognise where the injector is from, it doesn't look like something I've seen in the past.
now
It seems to me that this would be an incredible modification to carry out on an LPG vehicle. MS installations are already pretty easy to carry out, and it would probably be easier to tune than a conventional vapouriser equipped vehicle. With the latent heat in LPG turning into gasseous LPG in either the intake manifold (TBI) or in the cylinder (multipoint), turbocharging on standard compression ratios becomes a viable option, since it would chill the intake charge somewhat more than an Intercooler ever will.
Thoughts? Comments?
edit: apparently theyre the Bosch LPi Injectors.
now
Thoughts? Comments?
