LSA question?
Does anyone know if a wide LSA or narrow (108-114?) gives a better part throttle responce in a 250 I6.
At what RPM? A wide angle is generally better for throttle response; this is especially true at the lower RPMs.
what is an LSA? my throttle response isnt that great and i have my stock motor set up for the best i can get so if this LSA thing will help then that would be cool.
health food shops were overrun with people wanting to buy LSA, a mixture of linseed, sunflower seeds, and almonds...
Seriously, it's Lobe Separation Angle, an intrinsic aspect of the cam design. Just one more consideration when choosing a higher performance camshaft for an engine...
The reality for me is that I usually cruise on very low rpms about 2200 rpm due to the speed limit of 80 kph on my journey to work. Im looking to maximise economy down low while still pushing higher rpm when I want it. From what Ive read a wider LSA helps with this I think, due in part due in to better part throttle responce? I was surprised to find that the gen 111 engines have about a 118 LSA.
I know there is some benefit with a narrower LSA at WOT. Trouble is no one Ive seen tests power at part throttle and this is where it may matter most.
I realise the questions a bit relative to duration, but a generisation would do. If anyones up to it?
Any Marine will tell you that LSA stands for Lubrication, Small Arms. It's great stuff, comes in a small green bottle. Not sure where to apply it on my Ford though :wink:
Joe
Dad has some of that stuff
used it when i was home last when cleanin my .22 (i had been plinkin)
then i cleaned the 30-30 an used some more (then i had been holin*)
i like the smell of it
* - "plink" was the noise the 22 made on the 1/4" steel, a hole was what the 30-30 made
I put a couple of posts on here a couple of days ago does anyone know where they went???
Re-posted couple of replies from Sam B at C.O.M.E engines on cam selection and LSAs.
You recommended the CLH 191.
Q1, Is the CLH 191 a dual pattern cam? The duration at 50 is 217/218 but the advertised says it has a 12 degree separation between the inlet and exhaust (278 290 I think).
Reply, Intake lobes are very often faster acting to open vale more quickly to fill cylinders.
Exhaust lobes don't need such fast opening rates as the inertia of
exhaust gases is incredibly powerful and better gas velocity is actually
achieved by opening slightly slower. Doesn't apply to all cases, depends
on port type.
Q2, Does a wider lobe separation angle ( such as this one has 114) with around this duration tend to give better economy than one with a shorter LSA?
Reply, Yes better economy potential but slightly less peak torque and longer spread of torque which is better for daily use.
Another reply on very wide LSA quiery?
EFI engines are different up to a point.
The 118 lca in a Gen 3 is actually closer to 120 degrees.
Reason, less low down torque to reduce transmission and diff breakages.
Better emissions.
More top end power, so the factory power figures look better.
Like any factory deal, it's a compromise trying to achieve a good
outcome in many areas.
Sam
