So, I grabbed a spare 1980 head from the junk yard for the 200 in my '66 Mustang. I adapted it for a 2 barrel Weber 32/36 and sent it off to the machine shop for a hot tank, valve job, and to mill .075" off the surface (I measured just about 62 cc's in each cylinder, right about what the handbook suggested I would find).
Question 1
What do people do about the pushrods when machining a head with non-adjustable rocker arms? The handbook is pretty vague on the topic... I did find pushrods that are 1/16th (.0625") shorter than stock and put in an order for those from NAPA... probably a good idea at only $2.50 each. Think that will be sufficient? I mic'd the head gasket I pulled out and it was right around .055", probably the same thickness as the new Felpro I'll put in. Kind of concerned about just putting things together and seeing what will happen... but not sure what else I can do without adjustable rocker arms...
Question 2
Since I have things apart, I also decided to go for a new set of hydraulic lifters... I had no problem with the old ones, but didn't want to find one go bad in a few years after all the effort to put a new gasket, etc., in... again, at $4.00 each, it sounded like good insurance. Advice? The camshaft lobes looked good, no abnormal wear. Anything special I should do when I install them, other than just some assembly grease?
I also got some .060" thick washers to go under the head bolts and account for the change in head thickness.
I figure I'll put it all together, get it running and get the timing, then change the oil after a few trips around the block. (I know I got some coolant and other minor crud in the engine during the process).
Anything else I'm missing? I feel like I'm forgetting something or making a basic mistake here...
Question 1
Question 2
