73GreenMachine
After building up my 200ci log head, I have decided it is time to take the next step with this motor: remove the log. I am planning to design a proper 2v manifold for it along the lines of the 250 2v manifold. As far as I can see the log head with a proper manifold added would have the same performance as a 2v head. Is this right or are there differences? The current plan is to cut off the log, leaving the rear face of the log to use as a bolting flange. The intake pipes I am going to have actually running into the heads intake ports. This will help to fix the manifold to the head as well as reducing the port diameter slightly to help increase intake port velocity. I want to use mechanical method of joining the manifold on rather than welding it.I will draw some pictures soon so you can see what I am planning more clearly.
Has anybody on this forum gone about designing a new intake and if so how did you go about it? Any thoughts?
