Hi, am changing my Master cylinder on my 1968 mustang with manual drums and after taking off all the lines , did not take a picture as to what lines connect to the front/rear brake lines and which line from the master cylinder to the distribution block (dist).
What I remember is: the front master cylinder connects to the top rear of dist block (as mounted) the rear part Master cylinder connects to the front top of the dist; bottom of dist: left front brake line to front center of dist, and the two bottom connect front connection to right front and rear brake line to the rear (bottom) of dist?
Hope this make sence.
Thanks in Advance
Thanks in Advance
