An x-flow will take 60 thou over. My 228 has 56 thou over 305 Chevy pistons.
As Mike at FSPP and others say, bore the minimum amount to get the cross hatch , ovalarity and tapper within limits. In most cases, 30 thou does the trick.
Since most US engines went to modern thin wall (120-180 thou) green sand castings in 1963, any I6 or small block Ford made after 1963 prefers 30 thou over. That way, you've got a chance of a 50 year run out of a block With a lack of corriosion inhibitor typical of most backyard serviced Falcons, the wall thickness that was perhaps 120 around the cylinders in 1985 may be only 90 thou in 2005.
The text book rule is to check with a sonar ray or cover meter, and if you go to less than 10:1 compression , you need about 120 thou wall thickness against the thrust face of the piston.
