At last my new cam arrived yesterday (still be end of next week before machinist can come out and dial it in).
I thought I would do a cam comparison by measuring the base circle and lobe height of my new cam from Wade and compair it with my old cam (5000 km approx old) from Camtech.
The Camtech cam is supposed to be .278 inch lift at cam and the new one is supposed to be .284 on inlet and .287 on exhaust (cam lift).
The first thing I noticed was the shape of the lobes was very different, the Camtech cam had sharper peaks on the lobes and had worn a bit on this area. The contour of the Wade cam lobes looked a lot better.
That aside the thing that surprised me was the variation in the lobes. The Camtech cam varied from the lowest lobe being only .250 at cam and the highest was .272 at cam. Unfortunatley the new Wade cam was worse with the highest lift being .292 at cam and the lowest being only a .264 a variation of .042 of an inch = 1.08mm.
To tell you the truth I was definitely not impressed, but not very surprised. Im still not sure if this would adversly effect anything or not.
Ill give some of the other readings of lift at cam in mm for compair. You can see most are good but theres a few bad ones in the bunch.
Camtech starting at front at 1 was 6.76mm, 6.90, 6.93, 6.70, 6.70, 6.80, 6.69, 6.70, 6.86, 6.80, 6.35, 6.70.
Wade was 1 at 7.31mm, 7.09, 7.16, 7.20, 7.10, 7.27, 7.30, 7.11, 7.30, 6.71, 7.07, 7.43.
The Camtech cam has been run for 5000 km with high quality springs at a near perfect seat pressure of 90 lbs. I used a very accurate tool to measure the lobes and did many twice to check.
Comments?
Comments?
