LameHoof65
This kind of worries me since I have never done this before, but my anticipation is about to overcome the worry. I have a pretty good idea on how it is done and I have read quite a bit on the methods with and with out the head on the block. I have seen a few cams installed in the past but like everybody else I was more interested in how it was going to sound and perform than following the process. Here is what I have:
1) Moroso 11" degree wheel
2) 1" dial indicator
3) coat hangar (sophisticated & precision machined) hangar out of my wifes closet
4) Head and oil pan off
5) Old lifters still in the engine
6) Cam lube
7) Pulley Puller (if necessary)
Now here is where I am a bit shaky on the topic.... there are two processes involved in doing a complete cam degree. To get the cam at approximately 10* BTDC---is the best to ensure firing on initial startup. This involves first lining up your old cam and crank at TDC before pulling the sprockets. Then once lined up at TDC pull the crank and cam sprockets and remove chain. Now put the cam pulley back on and slowly rotate the cam out. Once the cam is out take off the cam sprocket and put it on the new cam. Lube up all the lobes and bearings on new cam and rotate it in with the cam sprocket.
Now this is where I run into problems: 1) install the crank sprocket at 0* with chain on cam sprocket and line up the points as if they are both set at TDC as the old cam?---How do you know that the sprocket and the cam are in fact in position of TDC (ie., both valves closed) and consistant with the crank? Does the cam sprocket keyway as lined up with the TDC 0* and keyway make it impossible to not have the lobes on the cam in the right place? All this is the initial process as I see it.
Once TDC is found with the cam and crank lined up....then the next process is to stab the distributor....(in my case the head is off and I probably won't actually put the distributor in until the head is back from the machinist and the head is on.) but for the purpose of clarification (lets say I have installed my head and I am now ready to stab my distributor---
I line the rotor on the distributor to the number 1 wire location and after lubing the gear put it in the block and slide it into the cam gear. (now in my case with the head on--before I do this I will rotate the oil pump with an old distributor shaft without the gearing, before I actually put in the distributor).
Once all of the above is complete I can then do the second part or the second process of the operation and check for valve lift using a 1" dial indicator on the retainer tops and see if the cam is actually opening and closing the intake and exhaust as the cam specs indicate....I know I could do this after setting the cam and crank at TDC with the head off by using a pushrod, dial indicator and a solid lifter....right.
Okay once the head is on, the cam specs checked and fuel lines, carb and ignition setup is hooked up--now I can set the advance for somewhere to BTDC say around 10* by slight rotation of distibutor once the car starts up---my question is how do you do that before the thing fires?
Also, I have heard of significant retarding on these engines and having to set 28* advance in some cases---now I am new at this and this may sound stupid---but to me that sounds weird...I know clay smith cams unlike say comp cams are not set at 4* advance to start with but man 28*'s to get your timing right.....
Oh, and the cam spec card that Mike sent me is for 1.6 rocker arm and I have the 1.5 adjustable---this is gonna sound stupid but how do you adjust the figures to less lift---I know there is a formula the 1.6 or in my case the 1.5 x's something or another but you have to have some exact numbers here don't you to calculate you valve opening and closing--which I see as the second and more comprerhensive part of degreeing the cam.
6) Cam lube
