roghax85
Hello All
I am new on buil. this is first build, Ford 1966 200 cid,
block and cilinder head from 1966.
new valves: http://classicinlines.com/proddetail.asp?prod=SIV-200-RSL
Stem: 5/16"
Intake: 1.750"
Exhaust: 1.380"
Installed Height: 1.68"
flat top Pistons to .20: http://www.summitracing.com/parts/SLP-W489P20/
cam 260: http://www.summitracing.com/parts/CCA-K65-236-4/
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,000-5,000
Intake Duration at 050 inch Lift 212
Exhaust Duration at 050 inch Lift 212
Duration at 050 inch Lift 212 int./212 exh.
Advertised Intake Duration 260
Advertised Exhaust Duration 260
Advertised Duration 260 int./260 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.440 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.440 in.
Valve Lift with Factory Rocker Arm Ratio 0.440 int./0.440 exh.
Lobe Separation (degrees) 110
cam of rod and main to 10
So: I need to know what is the minimum deck on the block to can use for daily and a CR max of 9.7
thanks
Stem: 5/16"
Intake: 1.750"
Exhaust: 1.380"
thanks
