I have been runnung 10W30 with a quart of slick 50. I did'nt see any smoke out of the tail pipe until about a month later. I read that the specs for the 200 I6 is supposed to be 15W40. The 10W30 just seems too watered down now that its getting warmer and my oil pressure is running a bit lower. Should I change the oil to the spec grade oil? I also see smoke on start ups and after the engine is warm and you shut it off and restart. If I change to the 15W40 oil do you think it will help with the smoking?
