In the past I have direct mounted the larger 250 oil pump but it doesn't fit well and the front bolt hole falls off the 200 block mounting boss. As you can see in the picture, the 200 flange is the smaller one on top of the 250 flange. The bolt holes are right on top of each other leaving no room for the bolt heads. This adapter bolts down to the block and the 250 pumps bolts to the top of the adapter. This adapter is 3" tall. I'm moving the engine up to straighten driveline issues, giving me more room to make a deep pan to keep the oil away from the crank. As you can see, it is designed this way to be very stout. A shorter one could be made but you'd have to use studs in the block and small reduced head 12 point like a non locking jet nut to hold it down. Losing at least one of the side ribs to be able to tighten it down. The drive shaft comes out at about 6" and I didn't like what the after market had so I made my own out of some TI grade 5. I made it a larger tighter fit. Factory stuff is pretty sloppy and I expect it to be as strong or stronger.
