Seems like a common request. Due to the extremely detailed info on this board, the Advanced search engine on the top right of the board is always the best option. Take it slowly, and you'll get every morsel of info on this subject
About 2003, one member here with a 2V headed T-code 65 GT replica had the same modifications as Mike suggests in the Classic Inline Technical pages (Click Fordsix moniker top left, and follow your nose).
see also the post called FSPP Header AC Bracket modification problems, by Guest, formerly Jimbo65. Its in this 144-250 "Small Block" Six Performance section. All his very accurate computer drawn links are dead though.
Like it is with the Pacemaker headers Mike sells, a York or Selectaire compressor on the true right of the header needs to be moved out a few inches in most cases. This can be done by just adding welded plates about 1/2" plus two 1/4" laps for about 1.75" to move the compressor out on its hanger.
Sometimes the suction line needs to be extended.
In most cases, that should do the trick.
I keep a vast array of old photos, but work 85 hrs a week so don't have much time to go through my old CD's and upload them to photobucket or email. I'll see what I can do, but I got reports to write for my roading job for the next two days, then im on night shift again.
