I have a low milage 144 in my falcon I'm building. and I was looking at my duaspark distributor. the only difference I can see is that the oil pump shaft is larger on the duraspark. so I was wondering if there is any reason I can't bore the hole in my block and buy a late model oil pump to get the advantages of the electronic dizzy. I am building this car for maxium economy and building it as low cost as possible so I really rather not go to a later 170. also if I go to a duraspark will my 144 carb work with the vacume tap plugged off? Thanx
