Stock 250 cam specs?
It's dual profile; think the intake is about 252° advertised duration. Maybe an extra 6° on the exhaust. Not sure on the lobe separation. I measured 221 thou lift on the intake and 229 thou on the exhaust but you need to multiply that by the nominal rocker ratio. Cam timing is reasonably described as "retarded".
BTW, I think you need the JP5608 timing set if you want a multi- adjustable one. May be worth checking with Az.
