the adaptor on DS2 distributors is only needed for the big cap with the male plug terminals.
A smaller cap is also available, quite similar to the points-type cap.
I have seen DS1 distributors before, those early units basically had a points-type housing with spring clips and a points-type cap. I bet it even was a common breaker point distributor cap.
below, you see a common black breaker point cap, right next to a small DS2cap (breakerpoint
style)
below, you see what the DS2 pattern looks like, on both distributor and cap.
the big cap with the male terminals spaces widely apart uses an adaptor with the same pattern. I´d have shot a pic of that as well, but its out in the garage somewhere.
numbers for the small caps for DS2:
- Motorcraft EDH 109
- Standard FD148
- Echlin FA104
- mileage plus FA104SB
- Facet 2-7787PHT
numbers for the big cap:
- Echlin FA136 (cap)
- Echlin FA139 (adaptor)
- mileage plus FA136SB (cap)
- mileage plus FA139SB (adaptor)
- Conrad F2104G (cap)
