HI all
Well I am new to the board, let me just start off by saying thanks for all the help ahead of time! My name is Bryce, I ahve a 66 uncut halfcab Bronco with a stock 170 I just replaced the points for the first time. With sucses I might add! I installed new plugs and cap and rotor. But now the carb is leaking. So I to it apart and I am now soaking it in gunk carb cleaner. But I have a bigger prob now. Two of the rubber seals that are in it are basically junk, one is the black seal that seals aroud an about 1/4 or smaller rod that if I remember goes through near the top of the float bowl. and the othere seal was inside I belive at the power valve actuator? Does that sound right that seal was red. I looked up a seal kit on napa and it looks like the right one it says it is for a holley 740? But when I type that into yahoo search it comes up as a 2 bbl? What gives? And the gasket kit even though it lookes right it does not have the two rubber seal i need to rebuild this carb. And a rebuilt one is 168.00 from Napa.
Can anyone help me with some right direction? If there is anymore info I can give let me know! this is the #'s I got off of the carb.
301G D0PF-9510R 4533 OKC
6R
3514
B
Thanks again
Bryce
6R
3514
B
Thanks again
Bryce
