Caballo Diablo
Active member
I think I have read all or at least most of threads regarding the Duraspark conversion, but I still have a problem that I need help with.
First it is a 66 mustang/200cid/C4...it runs fine with the 1101 and LOM.
I bought a new Duraspark II/spark plugs and wires/coil/HEI at O'Reilly's.
I have it running...sort of. At 1000rpm or higher it runs well, sounds smooth, but one hair below 1000rpms and it dies abruptly, or If I put it in gear, it dies abruptly.. What I mean by "dies abruptly" is that is does not stumble and die, it dies like turning off a switch. I have the HEI mounted to a huge aluminum heat sink. I don't have vacuum connected to the dizzy, will do that when I get it to idle somewhere near normal and can put it in gear without it quiting.
Any suggestions on how to troubleshoot/isolate the problem? Don't assume I know anything, I only got this far because of what I have read on these forums.
Thanks,
Mitch
Thanks,
Mitch
