Just finished up a few projects, installed my transgo shift kit and took it for a test drive this morning.
I like how you can hold a gear to any rpm but one thing I'm going to have to be carefull is that you can downshift any gear at any rpm
Dont ask....
Anyway,
I made up a new carb heatshield and I was curious if I should line the bottom side with any heat reflecting material? It's aluminum stock 6"x20" with the shiny aluminum facing up and the white powdercoated side facing the headers.
In the summer the carb bowl heats up hot enough that you can lay your hand on it for only a few seconds before it starts to burn.
Also got my cool can plumbed up.
Would there be any benefit in shielding the fuel line from the carb to the firewall filter with some of that foam pipe insulation that you can buy at the hardware store?
Thanks,
Doug
Dont ask....
Anyway,
Thanks,
Doug
