61EconoDave
I purchased a 1966 200 yesterday. I lucked out and it already has a 1980 head. Due to the fact that there was no carb on it, there was some crud inside the log. I figured the head needed to be removed so this could be fixed. I take off the valve cover and find out that it is super clean on the inside with adjustable rockers. The next problem I found was rust had fallen from the top of the valve cover onto the whole center section of the rocker arms and down the push rod shafts of 3 and 4. If I could have cleaned it up without having to take the head off, I would have. The rust deposits was really thick, mostly on the rocker shaft springs.
I take the head off this morning and this is where I ran into my most major problem. Number one cylinder was full of water. The cylinder wall is crusty with rust and scale. 2 of the other cylinders have slight rust that rubs off easily. The pistons are stamped .030 letting me know that the bottom was taken apart at one time.
This motor is so clean on the inside and out that the only evidence that it has ever ran was where the exhaust manifold didn't seal good. There are no wear marks anywhere inside this motor.
I have no clue on how to precede with this motor. Do I resleave, go to a bigger piston for just the one cylinder, or all of them, stop where I'm at and start looking for another 200, or what? I have never been to a machine shop so I don't know what to tell them when I get there.
David in Huntsville AL
1961 Econoline Pickup
