If I run twin turbos and both are set at 8lbs pressure and both feed into a Y tube for single inlet intercooler what will the pressure be at the intercooler?
I know pressure at the throttle body inlet will depend on how much pressure drop through the intercooler but not sure if pressure doubles where two turbos pump into one pipe.
I plan on running a blow off valve on intake side to control pressure and prevent intake side damage.
