This is sure to get 'Extasy' out from his NZ lock down.
So Phil Irving was a famous Australian 'motor' engineer. in the 1940's 50's, 60's , 70's
He was born in Australia and in 1930 went as pillion passenger on a Early Vincent 600cc side valve motorbike from Australia to Britain - via canada.
ended up with a job for Velocette and Vincent in England and designed the famous Vincent V twin motorbike
spent WW2 in Britain design stuff for the war effort .
post WW2 he designed more engines and returned to Australia,
in the 60's he designed (well modified ) a version the Buick alloy stock block that Jack Brabham used in Formula 1 to win the new 3 litre formula world championship in 1966 and his team mate , denny Hulme , again in 1967..
so by early 1970's he had a great pedigree.
a local company 'Perfect-tune ' got him to design a 12 port head for the local Holden (GM) six engine (capacity 179, 186, and eventually 202ci) for hot street and racing
Perfectune also launched 'Yella terra ' parts and are still going.
anyways they made about 26 heads in alloy and the 'Irving head venture' folded.
heres Phil Irving in about 1972 in a magazine advert for the yella terra Irving head :
and installed on a holden 6 - almost a mirror image of the ford 6
whats this got to do with Ford sixes i hear you ask.
the Holden engine has the inlets and exhaust on the (USA) drivers side . with siamesed inlet ports ...
the Ford six has the inlet /exhaust on the (USA )passenger side.
But by some co -incidence they share the same bore spacing.
so some clever dudes in Australia in the the early 70's turned the heads around for the correct port orientation and made them fit the ford six - i think for speedway - but only a few - maybe 3 or so were done (remember only 26 odd heads made.)
by 1975 ford Australia had its own 'crossflow' ford six heads with removable inlet/exhaust manifolds - so not much use for an irving head.
Phil Irving - Wikipedia
en.wikipedia.org
