I am installing a new head gasket on the old Ford. It was using some coolant last fall and now when you fire it up, it has a definite miss and smokes/smells like coolant.
Pulled the valve cover and there is coolant laying on top of the head, under the valve cover.
I have read about milling the head for the new gaskets and that will require washers under the head bolts, right?
What if you don't take much off the head. Will performance difference really be noticeable? If so, where do you get the hardned steel washers to put under the head bolts and how thick do they need to be?
I really appreciate advice from the experts here!
