6cylfever":3gr8zzjs said:Is the 12-counterweight crank only available from Oz? If I ask for one what is it put in? What year? Is it for the 250 overhead cam crank? Do you think it is available from rebuiders or only new? Thanks Marv
The 12-counterweight crank is only available from OZ. It was used in the EF Falcon of the mid-90's with the 4.0L OHC engine. If your looking for one, that's what you will have to ask for. You may be able to get one from a rebuilder, or from a recycler (wrecking yard) but make sure it has been crack checked before purchasing (it's a long ways to get a replacement).
This crank will drop into a 4.1L crossflow block with the casting code 84DA or 86DA because they use the same rear main seal. Earlier blocks will have to be machined to accept the rear main, or the rear flange of the 4.0L crank turned down to accept the earlier seal (the disadvantage of turning the flange is you could weaken the area where the flywheel bolts go in). The advantage of the 12-counterweight crank is the ability to rev the engine above 6000 without fear of failure; the x-flows get very bad harmonics at around 5800-6000rpm and the balancer or flywheel may shake lose.
Hope this helps.
