Truck is a 1962 f-100 lwb fleetside. Vin# from glove box is F10JE320759
Casting # from left rear area of block is C3AE-6015-F.
If from what i've been reading, this motor is a 1963 make. OR does this really mean that this could still be the oringal motor? Need to find out size of motor. I pulled valve cover and 3 pushrods were not in line with rockers
middle section of rocker section looked dry. Checked oil pressure, it was around 50psi. The back oil tube that feeds rockers weas stopped up where it goes into rocker assembley. Does the pushrods, rockers and rocker support rod and related parts the same for 223 and 262 motor?
Also in the owners manual in the truck someone had circled the 262 engine? Maybe?
