This thing is cool.
For those of you who haven't seen this, this calculator beats the snot out of the crappy version I have been using from linc's writeup that simply did the airflow math for you and required you to chase maps from another location. This does the same math, but also graphs the airflow based on your inputs. You can select several maps at the bottom of the page and compare them side by side as the calculator actually graphs your airflow based on your inputs. You can then tweak your figures and see how the different compressors flow accordingly. This is a GREAT page. I was pleased to see that the compressor I will be using looks to be the best choice out of the 4 that I was considering.
http://www.squirrelpf.com/turbocalc/ind ... ap_sel4=79
