Drag-200stang,
Yes the normal Corteco gasket never seemed to hold up. Now with that said I also couldn't get the Demon 500cfm carb to work correct either. (as you saw at Indy!) So the tune-up was the root cause for multiple head gasket failures.
So on went the copper gasket. It's made by a company in Cali.
http://www.headgasket.com is the website. Talk to Mordy.
He and I are finishing up the gasket design. He originally just digitized a Felpro gasket, set up his machine and sent us one. So I'm taking the oppurtunity to optimize the gasket for the maximum surface area for sealing. We're also working on making sure the bore centers are exactly right.
Last Friday night we took Kelly's Falcon to the track for some testing of the new equipment. That would include a Oz 250-2v head, a modified Oz intake manifold set up with a Holley 450cfm mech. secondaries carb and the .054" thick copper head gasket.
She only made one pass due to water in the oil. The head gasket was already seeping. Also the carb was acting funny. I believe we had a vacuum leak somewhere. The A/F ratio was all over the place at idle and at cruise. Never did figure it out.
But she ran a 12.81@106 at only 9lbs. of boost. So that cyl. head is a whole bunch better than the log head. According to our charting, it would've taken about 12lbs. of boost with the log head to get approx. the same ET/MPH.
We already have the motor tore down the head reinstalled. I cleaned the copper head gasket and the O-ring imprints look very good. Looks like it going to work fine. We trying "Yamabond" to seal up the water and oil passages in addition to the head gasket spray stuff.
We race again at FFW up in Phoenix in three weeks, so hopefully we'll have the new carb and gasket leakage sorted out by then.
But the Oz head is looking very promising....can't wait for the aluminum one!
Later,
Will
