Offy, power brakes, and auto trans.
Can you run an Offy setup with power brakes? I know the vacuum in the manifold drops when all the carbs are open, but 99.9% of the time when you hit the brakes, you don't have your foot on the accelerator with the carbs open, either.
Would there also be enough vacuum to control shifting in the auto transmisison? If not, I guess you could always get a manual valve body.
