This mixer, able to be mounted for sidedraft operation, flows 450 cfm. I figure that's plenty of flow for my setup.
Wondering if I can just fab up a plate, center the bore over the divided plenum and go, or if this might flow uneven into the two collectors??
For the record, this is a carb engine, higher compression engine running on Propane (as the signature states)
I am looking for an ideal replacement for a stock carb manifold, which I am using with a 1bbl adapter for the OHG mixer currently.. no flow, no go. bad mileage.
